Skip to main content
Render Text and Store as Variable
The Render Text and Store as Variable action fills in a text expression with actual values and stores the result as a variable that later actions can use.
Use this action to transform and combine your automation's data (email, ticket, API responses, etc.) for use in later actions.
When to Use This Action​
Use this action when:
  • You need to capture or transform data from available automation variables for use in later actions
  • You are combining multiple values into a single computed string (e.g., building a ticket title from email fields)
  • You want to store intermediate results for conditional logic or repeated use
  • You are creating formatted output from template expressions
Don't use this action for:
  • Multiple extractions at once: Use Extract Strings to extract several named values in a single step.
  • Pattern-based extraction: Use Perform a Regular Expression Match when you need to extract values using regex patterns.
  • AI-driven transformation: Use Prompt AI when you need AI to analyze or transform text intelligently.
Configuration​
FieldDescription
Text to RenderA text area that supports text expressions with {{variable}} syntax. The entire contents become a single text value.
Examples​
  • Store email subject: {{email.subject}}
  • Combine fields: New ticket from {{email.from.display}} ({{email.from.address}})
  • Use helpers: {{uppercase email.subject}}
Returned Variables​
When you configure Store the results in Variable, the finished text becomes available for later actions.
VariableTypeDescription
(root)stringThe finished text, with every expression filled in
Access via {{custom.<variableName>}} where <variableName> is the variable name you assigned to this action.
