Skip to main content
Limited Release
This action is in limited release and is not generally available.
Wait for Approval
The Wait for Approval action pauses an automation and sends an approval request email to a designated recipient. The automation remains paused until the recipient approves or rejects the request, or until the configured expiration window elapses.
When to Use This Action​
Use this action when:
  • An automation needs human approval before proceeding with sensitive or irreversible actions (e.g., deleting records, sending bulk communications, modifying configuration)
  • An external stakeholder needs to review and sign off on an automated request before it continues
  • You want to build a change management or expense approval step into an automation
Configuration​
FieldDescription
Email AddressThe recipient who will receive the approval request email. Supports text expressions. After any text expressions fill in, the value must be a valid email address. If it is invalid, the automation stops with an exception and does not create an approval request.
SubjectSubject line for the approval email. Supports text expressions.
MessageApproval request message body explaining what is being requested. Supports text expressions.
Expires In (Hours)How long the approval request remains active before expiring. Minimum 1 hour, maximum 168 hours (7 days), default 24 hours.
Allow Approver to Add CommentsWhen enabled, the approver can include comments with their approval or rejection response.
Approval Input FieldsOptional fields the approver can review or complete before submitting a response. Field labels, descriptions, and default values support text expressions, so you can pre-fill fields from email data, parsed values, or earlier action results.
Action if RejectedControls what happens to the automation if the recipient rejects the request.
Action if ExpiredControls what happens to the automation if the request expires before the recipient responds.
Approval Input Fields support Date, Time, and Date and Time controls. These controls use the approver's browser-local value without timezone conversion. Configure either a fixed Default Value or Default to the current date/time. The current option fills the field when the approver opens the approval request.
Returned Variables​
If you set Store the results in Variable, the action returns an object with the following properties:
VariableTypeDescription
IsApprovedbooltrue when the request was approved.
IsRejectedbooltrue when the request was rejected.
IsExpiredbooltrue when the request expired before a response was received.
Statusapproved|rejected|expiredThe final disposition of the approval request.
CommentsstringComments provided by the approver. Empty string when no comments were given.
FieldsobjectValues submitted through Approval Input Fields, keyed by field name. For example, Fields.approved_amount. The example result includes every configured approval input field so later steps can reference those paths.
RespondedAtstring|nullISO-8601 timestamp of when the response was submitted. null if the request expired without a response.
Behavior​
  1. Sends an approval email to the configured recipient. The email contains a secure link for the approver to respond.
  2. Pauses the automation until the approver responds or the configured expiration window elapses.
  3. When the approver approves or rejects via the link, the automation resumes immediately.
  4. If approved, the automation continues and the action returns the result object.
  5. If rejected, the automation applies the configured Action if Rejected behavior.
  6. If no response arrives before the expiration window, the action marks the request as expired, the automation applies the configured Action if Expired behavior, and IsExpired becomes true.
Notes​
  • The action sends only one approval email per automation step. Re-running or retrying the step does not send duplicate emails.
  • The approval link is unique to the request and can only be used once. After responding, the link cannot be used again.
  • You can use the returned Status or boolean variables in subsequent If conditions to branch the automation based on the outcome.
  • Approval history entries include submitted comments and values from Approval Input Fields.
Availability​
This action is currently limited release.
